trying to post large pic under thread
CENTIPEDE
MMM:confused: has It worked?
IMG_0607
How is done?:confused:
5218493
Vegetoast
If you want to post a pic you need to upload to 4x4Earth as an attachment or an image hosting site of your choice then you can post it. Also reduce the photo's size and memory used so others can enjoy the photo instead of waiting for it to download.
Bmurry put me onto PIXresizer and its fast, simple and does batch resizing.
Link ---> Image resizing, do it with PIXresizer
I usually resize to 1024x768 or 800x600
I sometimes use Panoramio for picture hosting. eg:
Address of a photo --->http://commondatastorage.googleapis.com/static.panoramio.com/photos/original/34008932.jpg
I took out the M from IMG so you can see the code ---> [IG]http://commondatastorage.googleapis.com/static.panoramio.com/photos/original/34008932.jpg[/IG]
Good Luck!
PTCX
WOW,and I thought my trailer was small. just trying out this image insertion thing.Have I done it right?
Near enough I spose. Thanks for the info Vegetoast.
Vegetoast
photos
just trying out this image insertion thing.Have I done it right? Thanks for the info Vegetoast.
What you did was tried to post a web page as a pic.. you need the addy of the photo, in your case PTCX right click the photo and select image location then make your post, select insert image and the past the picci's address the just like you did with the web page.
