My next truck
Patriot
Administrator
Hey all,
Here is Tina and my next truck. It is perfect for taking the kids to kinder, or smashing Anderson Track at Gemmie. Leather seats for comfort. Not too sure about the sound system though. No need to worry about flat tires, it has run flats. It is a little bit heavier than the maverick, weighing in at 8,000 kg, but it does look pretty cool :)
Only 375,000 of your American Dollars too.
A bargain!!!!!!!
James
The KNIGHT-XV is an armoured vehicle and not a vehicle that has been armored. This means that unlike most vehicles that are armoured after-market, the KNIGHT XV is manufactured using military-grade armouring materials.
With its distinct size, extraordinary security features and ultra-luxurious interior appointments, the KNIGHT XV provides one of the most unique vehicle ownership experiences in today's SUV marketplace.
The innovative and incomparable KNIGHT XV takes approximately 1,500 hours to hand build with precision craftsmanship and attention to detail that one can expect from a vehicle of this caliber.
Length 240" (6096 mm)
Width 92" (2337 mm)
Ground clearance 14" (355 mm)
Height 100" (2540 mm)
The vehicle is built on a super duty specially modified Ford chassis platform (making parts and service easily accessible globally).
Engine: Ford, V10, 6.8-litre gas engine with E-85 Ethanol Conversion system added, (referring to as Flex Fuel engine) Flexible fuel vehicles (FFVs) are designed to run on gasoline or a blend of up to 85% ethanol (E85). Diesel engine also available as an option.
Horsepower: 400 HP and 500 ft lbs. torque (approximately)
4 X 4: Electronic, push button 4WD
Transmission: 5- speed Torqshift automatic transmission
Brakes: Four-wheel disc anti-lock traction control
Wheelbase: 141" (3576 mm)
GVWR: 17,950lbs (8,159.09 kg)
Armored Curb Weight: The finished vehicle weight is approximately 12,000 lbs. (5,454.55 kg)
Fuel tank: 40 gallons (US) (151Litres)
Air conditioning: Factory Air conditioning in-cabin
Tires: Four LT40X13.50R20 Mickey Thompson Baja Radial ATZ with ballistic run flats
Vehicle armor: The KNIGHT XV’s armouring level varies based each client’s specific requirements.
The following is a list of standard features on a basic luxury version of the KNIGHT XV vehicle:
Interior Appointments
Leather 6 way electric conference and cabin seating, total 6 passengers, in hand crafted Andrew Muirhead leather
Wilton Wool luxury carpeting
Spacious extended interior
Alpine AM, FM, CD, DVD, Navigation and Bluetooth equipment
Front power windows
Ultra Suede interior finish throughout
Leather-wrapped steering wheel
Interior lighting, map/courtesy and ambient
Dual screen rear console (remote controlled inputs)
Personal rear seat side mounted laptop stations
Exterior Appointments
Stainless steel running boards (side and rear mounted)
Knight XV 20" polished rims, forged from 6061 aluminum
Mickey Thompson 40" Baja tires
Fascia mounted PIAA dual mode fog and driving lamps
Heated, telescoping side view mirrors
Security Appointments
FLIR night vision cameras*** mounted front and rear, on individual screens
Roof mounted rear view camera
Keyless entry system
Transparent, tinted, armour glass throughout
Tandem tinted moon roof panels (transparent armour) with privacy shades
ASC Ballistic run flat system on all tires
Securilok** passive anti theft key system
** Torqshift and Securilok are registered trademarks of Ford Motor Co.
*** The PathfindIR Thermal imaging Camera offers dramatically better performance compared to traditional Night Vision Cameras.The FLIR Systems PathFindIR is a compact thermal imaging camera that significantly reduces the hazards of night time driving. This Automotive Night Vision Systems enable drivers to see much further, with improved clarity, than with standard headlights. Drivers can detect and monitor pedestrians, animals, or objects on or near the road, allowing more time to react to any potential danger. PathFindIR Thermal imager helps to detect and recognize potential hazards in total darkness, smoke, rain and snow.
FLIR PathFindIR is standard equipment on all Knight XV vehicles sold in North America
The KIGHT XV is built using ballistic hardened steel, making it fully armoured including ballistic fiberglass fenders, bumper and up to 64 mm. (2 and a 1/2 inches) transparent armour (glass).
Ballistic Run-flat tire system -
Tires and Rims: 40" tires with specialized custom designed and engineered 20" rims that utilize forged 6061 aluminum - the same used on commercial aircraft landing gear. The outer flange was reinforced to exceed to four times the normal impact testing required for standard wheels. Coupled with its ballistic run flat tire system it creates the pinnacle of safety in tire and wheel system exceeding anything on the market today.
millsy
Should be good for a few ford crossings when the river is flowing quickly - 5.5 tonnes!
Patriot
Administrator
It can go up to 8000 kg. The extra weight is for the add on armour that you may or may not need. No one has tried to kill me in a vehicle ambush for at least a couple of months, so I will skimp on some of the armour and try to keep the weight down. Better for the fuel economy, that is my little effort to help the environment :) :) :)
I really like that truck!
James
bmurray2250
The upside is when silly sports cars or crazy bike riders cut you off, you would only feel a small bump (if that). You would always has the right of way in any road or offroad conditions and no one will park beside you in a car park. :eek:
Patriot
Administrator
I haven't check the fuel economy on it, but being US built, I am sure it is very economical :) :)
James
Grey Ghost
5th Annual Victorian Gathering member
Won't you need that extra armour weight so that you have the mass to pull stuck cruisers and pootrols out of the mud etc?
bmurray2250
You would have to add a thicker mix of concrete in the driveway and car port to support the weight. It better come with a winch as no recovery gear is going to get you out of a bog
Patriot
Administrator
I wish!!!! It would be hilarious fun. But no, I will be there in the trusty Maverick. Got it back form the mechanic yesterday. Start packing tomorrow.
James
Grey Ghost
Knight-XV / Maverick..... I thought they were about the same anyway, except one is painted white so the terrorists can spot it easier.
Davidman
You and Andersons Track really sound like you've got it in for each other. I know where your coming from though, looking forward to it being re-opened ( if ever ) to 'attack' it again.
Patriot
Administrator
It was the site of my first and worst humiliation ever :( The Maverick awaits to avenge the Patriot :)
No surrender - No Mercy!!!!!
James
cloughcarib
I'm not a fan of fords, but I always thought that the f650 would be a good upgrade
