Gardens of Stone
Superdad
Although there were no takers, no doubt due to fact this was very last minute and it was mid week, I headed out to Lithgow on Thursday by myself. My cruiser has just had some mods done (incl rear locker) and I was keen to try them out and my weekends are booked up between now and Xmas.
Decided to try the double black run in the Boiling Billy book from Lidsdale to Ben Bullen via the Gardens of Stone NP. A few people had commented that it was really not that hard and I wanted something to test the cruiser.
Just after hitting the dirt and airing down, you are presented with a pretty steep and rutted climb with some reasonable steps and holes. Perfect to test the lockers. Engaged the rear locker, starting crawling up the hill and... started spinning wheels and ceased progress.
After much muttering under my breath and I gave it another run with a slightly different line and a bit more on the right foot… only to lose forward momentum again with front wheel spinning madly.
I backed down the hill thoroughly deflated and started considering what other tracks I could try when I glanced at my dashboard and realised the centre diff lock was not engaged.
One of the mods I had done was to disengage the auto diff lock in low range and I had forgotten to engage it meaning I had a beautifully locked up rear diff and all power exiting through a front spinning wheel….
Once this was locked, the cruiser crawled up perfectly – a track I could not have done without the locker (maybe a better driver could do it unlocked but not me).
Once over this, the drive is pretty easy along the escarpment with absolutely stunning views of the Wolgan Valley. For any photographers, sunset here would be amazing against the sandstone.
About half way along there was one more serious challenge - a steep decent with a big step down off of a slab rock surface half way down. It was downhill so I was not worried so much about traction as I was about entry and departure angles. I did not want to get hung up alone even though I did have recovery gear.
Looking at it though, I could not really see a reason the car would not make it so gave it a go and she crawled down beautifully. Did not scrape anything and traction was maintained.
Rest of the trip had a few ruts and some big mud holes but all the big ones had chicken tracks which I took seeing as I was solo.
A great drive that would make a great day trip if linked up with Lost City or something out to Turon
Definitely not for AWD’s but in the dry, a 4WD with decent clearance should be fine, especially if a mate has a winch and can drag you up that first steep climb.
In the wet, you’re on your own….
Wang
Good on ya. I seriously thought about chucking a sickie today and joining you:) as dont think i can make the weekend trip either. I still haven't tested out the new suspension on the patrol yet:mad:
Superdad
Yeah, on a somewhat serious note, I had 2 colleagues pass away with cancer this week so i figured phuck it! The window is open, gotta go!
Iain
Can you bypass this first climb?
I recall climbing it almost 18 months ago in a group of about 12, and only two of us made it up unassited, my Jeep and another, but with time passing, I am pretty sure it would be too hard for my stock Wrangler now so was wondering if I can climb another way?
The only alternative I can think of is to drive from the other way?
I have some friends from overseas and would like to show them the Lost City + Blackfellows Hand Trail and something else to make a day of it.
Thoughts?
Superdad
Thoughts?
According to Hema, there is the White Gate Trail that comes off the highway and joins the trail half way along. Not sure if it joins above or below the rock step though and you want to be joining above the step to get the great views.
Its a bit further but you could just drive the Turon to Sofala track. That's a pretty easy and really stunning drive.
Toddyh
Thoughts?
You can absolutely bypass that first climb although I wouldn't imagine a wrangler would have too much trouble with it. The left side is seriously eroded but the rocks on the right side don't change much. If you want to bypass it just take the powerline track further south off Wolgan Road. Then you can either take a small track off to the right a few kms in or follow it to the end. If you follow to the end you will need to back track to get to the lookout. Both options come out on the high side of the rock step.
Iain
Thankyou for the replies.
Yes it looks the Jeep will be continuing on her adventure.
Might even inlcude a side trip into Lisdale State Forest.
Cheers,
Iain
