2009 O'Tooles Flat Gathering
Status
Not open for further replies.
Grumpy
Yes! it's back again O'Tooles 2009
When: November 12th,13th,14th,15th & 16th
Expressions of interest are required for a gathering at O'Tooles Flat. It doesn't matter if your a complete Newbie or a seasoned Pro, there will be something for everyone, so why not bring the family.Tracks in the area range from Easy to Hard.
UHF channel 25, unless advised otherwise.
Requirements: NB No fuel after Moe. All Terrain tyres preferred, snatch strap & recovery points front & rear, rated shackles only. Your vehicle must have as a minimum third party insurance. You must be self sufficient with your camping gear and bring enough food (alternative arrangements should be made in the event of a total fire ban) and water for the weekend. You will need a hat, sunglasses, wet weather clothing, and strong walking boots. Last but not least, A sense of humor!
Trip Ratings http://www.4x4earth.com.au/forum/5893-post26.html
Convoy Procedures http://www.4x4earth.com.au/forum/5892-post25.html
No Rubbish Bins at O'Tooles Flat! If you bring it in, take it out!
Hooning in the camping area is not an option so please Do not do it.
If you can see dust in your mirrors you are going too fast, Safety First.
We will be going through cleaning up the O'Tooles thread from time to time so please don't be offended if your post gets done, it will make it easier for people to look through.
STARTERS and Numbers as of 22.09.2009.
1 4x4 (Rossco) 1 Rego in *
2 GRUMPY and DEB 2 Rego in Thursday
Convoy from Morwell Thurs (PM me for Details)
3 GUNNA and EMUS 4 Rego in Thurs
4 BEK 2?
Rego in Thurs Convoy S.A. mob in on Thurs
5 WOMBAT & Family 4? Rego in Unable to attend now
6 Knot_Gillty 4 Rego in Thurs Convoy from Moe Thurs 8.30am (PM me for Details)
7 Coxy and Lewis 2 Rego in Fri
8 Jimbob 4 Rego in
9
Sth Aust. Lowlux 2 Rego in Thurs
10 Sth Aust. EKKI 2 Rego in Thurs
11 Nickj 3or4 Rego in
12 MUTLEE HEE HEE 2 Rego in
13 Pistol Unable to attend
14 N.S.W. billolga 2 Rego in
15 Gippsurfer 5 Thurs Rego in
16 oznog05 4 Fri Rego in *
17 Davidman & Family 3 Rego in
18 Robz 4 Rego in
19 N.S.W. Walkabout 2 Rego in
20
Grey Ghost & GP 4 Rego in Fri Convoy from Moe Fri & Sat (PM me for Details)
21 Bainsy & La'toya 2 Fri Convoy from Moe Fri Rego in
22 Blue4b 4 Rego in Thurs
23
Knackers 1 Rego in
24 QLD. Yobbo 1 Rego in
25 BUSHNUT 1 Rego in *
26
WLDTI & family 4 Rego in
27 BradsGQ less the GQ 1 Rego in
28 Saltwater003 2? Rego in *
29 Dirty9 5 Thurs * Rego in
30 Sth Aust. Jacked Surf 1 Thurs Rego in
31 GriffoF100 1? Rego in
32 InSanE 1 Rego in
33 Offrdn60 1 Rego in Fri Unable to attend now
34
Bubba 1 Rego in
35 davidsmile 1? Rego in
36 Tuff Zook 2 Rego in Unable to attend
37 Tuf Triton 4 Rego in Unable to attend
38 Petera43 5 Rego in
39 Graham 3? Rego in
40 Richard 3? Rego in
41
Vitellan 4 Rego in
42 Traveller 4? Rego in *
43 GRIFF8 3 Rego in
44 Noel Wilson *
45 Nw 2 *
46 Nw 3 *
47 Boxerjohn *Sat
48 Davey Rego in
49 Davey 2 *
50
Davey 3 *
51 Davey 4 *
52 Sth Aust. BlackHat *Unable to attend
53 Donx 3 Rego in
54
55
56
57
58
59
60
To be Confirmed as of 17th August 2009
Shaneg 3
Petecruiser 2
N.S.W. theogs 4
N.S.W. Twinstacks & Shelley 2
Fox Shooter 1
93runnerdave 3
fencr 2
Mickyd 6?
rexy 4
N.S.W. Bertie 1?
Sth.Aust Dirty 6 1?
Sth. Aust. SoulSeeker 1?
Possible activity's as suggested by those going to O'tooles
Track runs are definite and probably another run into the Water Wheel too.
GPS Course & Map Reading if Required
Convoy Procedures
Possible to do set Night runs
New Event - Magic Markers Based on GPS C0-ordinates only
Below is Registration Form please download and fill in, then PM me for my email address CHEERS
Could I also ask you to put your Forum name ie- GRUMPY on the form please.
Also Emergency Envelope to stay in your glove box in case it is required. this is for your own Benefit so make sure it's easy to find. ( try using a bright envelope )
please read following post for directions to O'Tooles
__________________
Sometimes it's the destination, but mostly it's the journey !
  • O'Tooles Registration Form.doc
  • Emergency Information Envelope.doc
4X4
Grumpy, add me to the list!
Cheers Rossco
How to get to O’Tooles Flat with GPS POINTS
Basically the drive to Moe, Moccasins On Everybody ( Last chance for FUEL) then onto Erica then onto Rawson is pretty straight forward., Although you don’t go into Rawson but continue up to the Thompson Dam,
Drive over the dam wall and continue onto a T intersection
Walhalla Road
37 degrees,49'21.03"S - 146 degrees,24'25.39"E turn Left
Stay on the main road
TRIG Track on Right , do not turn into – PSA
CHERRY TREE TRACK on Left, do not turn into – PSA
CASCADE SPUR do not turn into – PSA
JUNCTION – keep to the right
PIPELINE TRACK on left. Do not turn into- PSA
DREAM CREEK TRACK on right, do not turn into – PSA
MERRINGTON TRACK
37 degrees,46'33.17" S - 146 degrees, 23'11.68" E
– TURN RIGHT
PLEASANT TRACK on right , do not turn into- PSA
SULLIVAN TRACK off to left, do not turn into- PSA ( there is also a track leading down to the right which leads you down to MERRINGTONS camp area- DO NOT GO DOWN THIS ONE )
You will cross over a stream / river and you will come to a JUNCTION,
37 degrees, 45'29.43" S - 146 degrees 24'13.62" E
to the right there is WILLIAMSON”S SPUR TRACK which is the most direct but is steep down Flats Track
NOT FOR NEW CHUMS
WILLIAMSON”S SPUR TRACK ,. TURN RIGHT
37 degrees 45'32.50" S - 146 degrees25'50.66" E
FLATS TRACK on left, TURN LEFT
It is a steep descent in spots but you will soon see a clear area lower down, this is O’TOOLES FLAT
FOR NEW CHUMS
At the T junction WILLIAMSON”S SPUR TRACK,TURN LEFT
Continue on Merringtons track and shortly you will come to another creek crossing,
37 degrees 45'28.68" S - 146 degrees 24'08.94" E
crossing the creek, off to your right is JUNCTION TRACK turn onto this
37 degrees 44'59.86" S - 146 degrees 24'18.44" E
JUNCTION- to the right .DONNELY CREEK ROAD,TURN RIGHT.
JUNCTION- to the left is WHITE STAR TRACK, do not turn into –PSA
TRACK ON LEFT, do not turn into, this leads into Little O’Tooles,- PSA
37 degree 44'59.89" S- 146 degrees 26'36.22" E
TRACK on left- TURN LEFT..
YOU HAVE ARRIVED !
Gunna
Here's a couple of pics from O'Toole's last year
BEK
CALLING ALL the SOUTH AUSTRALIANS
Well you wanted to come and see some high Country
Here is your chance
6 months notice would more do you need .....;)
...... Oh yes that's right Yes I'll be Going:D
If you are coming over let me know and I'll get a few extra days off to make it worth your while to see a lot of the area.
Davidman
5th Annual Victorian Gathering member
Put me down, plus 2 ( partner and daughter ). Will confirm closer to date, but at this stage, nothing planned and all should be fine.
knot_gillty
You should already have me up there!! You all know i wouldn't want to miss a weekend up near TOOMBON!!!!:eek::eek::eek::D:D
Me, Mezz and the kids will be there!!
Croozer
We will be there with bells on Grumpy. Croozer,Elise plus three.
The boys cant wait to see all the people from OTooles on the vic day.
OTOOLES IS THE ULTIMET 4X4EARTH VIC CAMPING WEEKEND! COME ONE COME ALL
Patriot
Administrator
Yeah, sounds good. I will check and see if I can get the time off work. Our whole family loved it last time, so hopefully we can make it again.
Cheers,
James
Blue4b
Put me down as tentative Grumpy:(, as soon as my leave aplication is approved I'll let you know to make it definite:).
Tony + 3 (at various stages of the weekend)
millsy
Hi BEK and Grumpy,
Would have loved to have come, but the dates are too hard. Slap bang in the middle of Term 4!
Is that a Victorian long weekend?
Traveller
Nah it's two weeks after Cup w/e here. Enough time for us all to recover from the gg's,
and hopefully not too many others at the camp spot-(probably more for their sake than ours!)
Knackers
Hi Grumpy, put me down as a maybe.
I had to leave last November on the Friday for weekend work. There will also be a weekend in November this year that I will need to work. At this stage I do not know which weekend in November I will have to work. If the work weekend does not clash with the O'Tooles weekend I will be at O'Tooles.
Will let you know as soon as I know.
Blue4b
Leave was approved, put me down as "confirmed" please Grumpy.:)
It's sad when you can't wait for the end of the year to hurry up and arrive.:eek:
Tony.
bubba
O'Tooles
You had better count me in x 1
After all the fun last year I would hate to miss out.
Bubba:p
Pistol
Put me down on the list too... and i'll see what other victims/sacrifices/winch*****es... i mean other nice people i can convince to come as well..
Status
