Narva Ultima 175
bmurray2250
I am looking to replace my stolen Lightforce 170 with the Narva Ultima 175 driving lights and wondering what other peoples experience with them? I may even upgrade them with a HID 4300K 35w kit in the future.
Because of the shape of TJM bulbar on the Prado, I can't fit many of the lights available besides the Lightforce 170 and the Ultima 175 or simular. I would love to install the Narva Ultima 225 but need an additional bracket off the present mounts. The rectangle driving lights like the IPF 800 series would fit but would prefer to keep with around light that uses a H3 or common bulb.
Pricing I have found to date are:
Narva Ultima 175 - $126
Narva Ultima 223 - $299
Lightforce 170 - $330
Lightforce 240 - $399
Pricing wise, Narva is well in front.
kyleb
I have the rectangular Ultima Blue 160/115 fitted (round equivelant is the 175s). They are not to bad, I went for the blues as I prefer the whiter light that they produce. They come with polycarb lens protectors.
The only issue I have had is with keeping them aligned, I went through a large puddle the other day resulting in water over the bonnet and found that this moved one of the lights so that it points off to the side of the road. It's easy to move it back though. Seems only to be a problem with sideways movement, perhaps all I need to do is tighten the mounting bolt up some more.
All up - for the price paid, I think they are a good buy and when I compared them against the light projected from a larger more expensive set of round driving lights, they performed as well, if not better
Davidman
5th Annual Victorian Gathering member
G'day bmurray2250,
I have the Narva 175's (round) mounted on the bullbar of the Pajero. I also went the blue ones because of the whiter light. I went for the set with one pencil beam and one wide beam, and through trial and error, found that it was better to mount the pencil beam on the drivers side. This lights up the road for a longer distance, while the other one does the roadside quite nicely.
In regards to keeping them aligned, I had a similar problem and asked the question in this forum. Suggestions and feedback can be found here http://www.4x4earth.com.au/forum/electrical/2496-spotlights-stopping-them-moving.html
What I found best was to insert a 5 mm thick piece of heavy rubber between the bullbar and the black polycarbonate mount of each light. This has effectively acted as a shock absorber for them and they haven't moved in the months since.
If I had a need to replace, I would probably go for the same type again.
bmurray2250
Thank you for the feedback this is very helpful. Happy to hear comparisons between other lights in a profile to fit my bar work. Even the IPF 800 series against the Narva lights
dtpitts
I have used 175's on my and my wife's road cars, Nissan Maxima for over 5 years on country roads , and Ultima 225,s on my Jeep for 6 mths and have not had to touch them since fitting, except for a couple of realignments on the Jeep, as you have heard the mounts are good but not for extreme use.
Hope this helps
GippsSurfer
Just installed a set of the 175's (Blue) yesterday.... WHAT a difference...
If you get them, the only bit of advice I can give you would be to get some extra wire and a fuse as the kits dont come with a lot of wire (And its quite small guage - just adequate, and no fuse.... 30amp inline would be best...)
Apart from that, they are easy to assemble, are very adjustable and a decent light for the money (Autobarn has the 175 blue kit on sale at the moment for $199)...
I would put up some pics but the camera battery is dead!
Good luck!...
bmurray2250
I have ordered the Narva Ultima 175 clear driving lamps from ONLINE AUTOPARTS and should arrive next week. I have rewired all my lights with relays and fuses a few years ago which has worked wonders. I only need to run wiring from the grill to the lamps as the thief that stole my LF 170's cut them off at there.
bmurray2250
Have installed the 175 lights today and just need to test them on a road and complete the alignment. Just a quick test and alignment in the garage looked good. Added a adjustment bracket to make the up/down cal easier and a set of anti-thief nuts also.
bmurray2250
Have ordered HID upgrade kit for the lights from eBay. Only going for the 35W 4300K bulbs which should give 500M from the driving lamps. I will upgrade 1 lamp and take photos for the difference between them.
bmurray2250
Just installed the HID kit into the Narva 175 and it looks good. The light is so much clearer. The park photos don't give justice but the Halogen just lite up the tree roughly 350m away where the HID lite them up well. Did some shots at home and in the park to give some examples. I will need to find a park and align the lights correctly now to get the benifits of the lights.
I have to finish the wiring and tidy up the harness but so far so good.:cool:
croozza
That's right HID all the way, one thing I found though with my Narva 225 HID's was I had to turn the Passenger side light towards the right a bit, this was due to the light reflecting back from street signs, It takes a bit to set HID lights right, as the light is so much brighter, so correct adjustment is critical.
bmurray2250
The HID kit I purchased has been returned for credit as some items failed. I am going to get any other kit soon but looking to get the 55w digital ballasts which should light up the road/bush ahead of me.
HID is the way, make the standard lights look like a old torch
Talisman
hi mate,
Sorry, just wondering who was the seller you were able to get the Narva Ultima's for $129 from?
I have a 90 Prado and and after a set.
cheers
Les
Davidman
Now I am getting my new lens's and lens covers for the Ultima 175 blues, thinking of upgrading the globes too. Don't really want to go HID at this stage, but wouldn't mind something a little brighter. Is it as simple as getting higher wattage globes, or does the relay also need upgrading. When I installed them, I upgraded the wiring to a heavier gauge and put a 30 amp inline fuse in the system.
Any input would be appreciated.
Thanks
bmurray2250
Without going HID, I would stick to the 100W bulbs I am sure if the heat from the 130W bulbs wouldn't burn the reflectors. Good wiring and relay will help the lamps. I run 30A cable to the relay (30A) and split the power over the 2 poles so I am only dragging 9A pre lamp. This means I run 15-20A wiring from the relay to each light. If one of the poles fail on the relay I till have one spottie working that is better than loosing all main lights at once.
