Cross Country v's HPD intercoolers
tremewen123
G'day lads, I'm after an intercooler for my 1hdt 80 series and have decided to go for a top mount. The two companies I'm trying to decide between are Cross country 4x4 and HPD (high performance diesel), price wise there's no significant difference. Just wondering if anyone has one of these brands and if you could pass on your thoughts in regard to quality and performance?
mauriceb
Xxii Industries W2a Intercooler Kit
If you want the very best intercooler for your 1hd i recommend the XXIINDUSTRIES water2air intercooler system made here in Brisbane i fitted one to my 1hdft in my 105series and its abolutely lethal. I have no association with the developer and manufacturer, Mark . I originally had the complete denco system and it can not be compared to the xxi system .If you understand about intercooler efficieny the denco was tested at 33%average at 100k/H on a 200km run where the xxii averaged 84% these a figures i calculated using a dual temp intercooler gauge and an outside ambient temp gauge with a formula To give you an idea under heavy load on hills the denco intake temps reached 72deg+ celcuis probably around same temps as a top mount and etg 300 deg where the xxii stabilized at 43deg with 270deg egt .The xxi top mount is massive with the liquid reserve mounted above the chassis rails with a total capacity of 16 liters, pumped by a 115 liter dav craig long life pump .The front heat exchanger is just on 600mm x300x 50 thick with 2x 10'' spall fans and this also drops the temp in the main radiator also uses transparent 25mm hoses
at 38deg ambient with the pwr radiator engine water temps dont exceed 86 deg on my vechicle This system in known to run up to 35psi boost using Gturbos and getting incredible fuel comsuption and amazing horsepower My fuel economy has dropped to 12.2L100 km at 100k/H and i have a very heavy 4x4 , click on home page
Home Page
Gregk6189
Hi Tremewen123
I have a cross country fitted to my Pajero and could not be happier Beautifully made cooler with PBR core. Speak to Jon there. Great guy with heaps of knowledge on the topic
Greg
mac_man_luke
Both are good and i doubt you could go wrong with either.
W2A as good option, allows you to have a front mounted cooler which is better for air flow but shorter pipe run of a top mount.
bally
Banned
a mate of mine has a BIG hp td42 gu... has run both of these coolers and split the hpd one twice.... thats with 250hp and 35psi.... the cross country one is still holding up fine now
Markymark
What pressure drop does he have with 35psi?
bally
Banned
there was a fair bit more with the hpd i believe.... was a while ago now so memory is a little hazy. i think with the cc one there was only 2-3psi (first number that came to mind) hpd was 5+
bally
Banned
im probably off with those numbers but i do remember him splitting two hpd's then not having that issue with the cc
Markymark
Is it the old style? What size? Any other info would be appreciated.
Sorry for the 20 questions. Its just good get other info. Ive found the opposite. The bar and plate has far less pressure drop, but doesnt cool very well. The tube and fin cools well but has alot of pressure drop. Had not found a single intercooler that could get close to 35psi. Most are useless at 23ish.
bally
Banned
sorry havnt got many other details..... all i can tell you was the cc i/c went on about 14 months ago and the hpd i/c were on before that. inlet size from memory was 2.5" as well but thats all i can remember....
tremewen123
Thanks for the info guys. I don't know a lot about intercoolers but I understand the merit in having a good one working well. The XXI Industries unit looks like a very good set up but I'd guess it gunna be double+ the price of the cross country air to air unit which I can see its worth that, I'd have to rehearse my justification speech to the minister of finance though.
58bernie
I have been running the XXi W2A intercooler for over 6 months at 30 psi with no issues and runs about 50 odd degrees below ambient temperatures.
Can't say the same for the Plazamamn W2A it had previous, it boiled it head off.
There is a thread in the 100series section on lcool with a 105 fitted with a 1HD-FTE with 233rwkw/312rwhp and 900+nm and running a XXi intercooler.
billolga
I love my Cross Country on the Patrol & it was dead easy to fit. I added a 50 Deg C thermal switch to the fan so it only runs when it's hot. There miles better than the Nissan one.
mauriceb
Just as a comparision to previous post, my xxi intercooler has not reached 50 deg cel even when the air temp on other side of cooler is 110/115 deg (pre) like i said in this thread it maxs out at 43c under extreme load ,cruising at 100km/h the intake temps sit around 32 to 35 degree im only running the standard ct 26 turbo at 14 psi . The Gturbos that a running much higher boost run up to 5 deg cooler.The large top air to air with fan on my previous 4x4 cruiser showed only improvment at highway speeds and the pre and post temps, from my gauges, on tracks, slow driving were almost the same .When you pull up and stop the heat from the engine causes heat soak , cooks the cooler causing same in/out temps) , it then take a while for it to recover and most times it wont untill you reach highway speed to push the air thru ,although a fan does improves it . If you really what to known if you cooler is actually working you need a dual temp intercooler gauge and the outside ambient temp and use this online formula .Intercooler Thermal Efficiency Calculator This will give you the results in % Would like to hear from any top mount air2air that get over 35% efficiency ,or if you get it dyno ask them also to give you figures without there 1000km/H Fans turned on and see the difference . The xxi system has given me up to 85% efficency
billolga
The 50 Deg C is the ENGINE BAY not the intercooler.
