I'm new and need help!!!
Recoding
I'm just trying to figure out my 4wd on my 1988 69 series land cruiser. Can anyone help? It will not engage into 4wd when I press the button.
LowLux
G'day Recoding.
Welcome to the site.
Got me lost with this, you say "It will not engage into 4wd when I press the button"....in a 1988 Cruiser? I didn't think they had a press button 4WD engagement system?
BOUNCY HJ61
Greetings Recoding,
And Welcome To Earth.
I Think You've Began With A Typo Error, There's No 69 Series Toyota, But I Bet Many Would Like One!!! Ha Ha Ha.
If Your 4WD System Wont Engage, Then Under The Bonnet There Are 2 Solenoids With Vacuum Hoses Attached. You Need To Reverse The Vacuum Hoses.
If This Fixes The Problem, Then You Need To Replace The Other Solenoid, If It Doesn't Then You Need To Replace Both Or Look For A Vacuum Leak Or Electrical Fault.
Read My Thread In "MY 4WD -BOUNCY" And You'll Find The Problem And Solution With Pictures.
http://www.4x4earth.com.au/forum/my-4wd/19581-bouncy-hj61-1987-a.html
Page 10
Cheers Michael
jack48
Put it in low range and try reversing a bit, my light does not always come on straight away, but it does after a few Ks.
Welcome by the way.
jack48
Took the Tonkatrol on the CSR, Tonkadore is only a weekend warrior a BJ 71, would not survive that trip :p;)
Recoding
Great advice
Do you know of a mechanic in perth? I have asked a few people and am pretty sure it is a vacuum issue but don't want to fix it myself and ruin it more. Is it even a mechanical issue?
Greetings Recoding,
Cheers Michael
BOUNCY HJ61
Greetings Recoding,
Page 10
Cheers Michael
The Terminals Are On The Front Of The Solenoids- Just Take A Look At My Pictures, And You'll Understand.
Cheers Michael
