Duel Battery System GQ RD28T
hiluxdriver
Hi All,
I'm looking to install a duel batt system in my 2.8TD, but am a complete novice when it comes to this stuff. I believe I can do the install no problem, but I need to know which parts to buy for my needs. I'm not out to re-invent the wheel so just the tried and tested systems are fine. All the batt will be running is a 60ltr fridge and some lights, this will be helped with a solar setup. I'll source a batt tray from ARB/Ironman/TJM, but what isolator do I need that will accept the solar panels? Maybe there is a kit available that has all the wiring + isolator? Is an anderson plug the best for connecting the solar?
Please feel free to add links to ebay for kits/items as this is my preffered way to purchase.
Thanks in advance.
Gavo
Mate in my humble opinion, you cannot go past a ctek dual 250s. It can be had for $250 and fits your needs perfectly.
Putting the smart charger technology aside, this unit will comfortably keep your second battery charged. And one huge advantage of this over other dc to dc brands is it has a solar panel regulator built in.
Simple to wire up, one earth wire then one wire from charger to each battery positive and your off.
I've used traditional smart isolators, and other than been able to join two batteries together (most are 100amp max anyway) the advantages of dc to dc well and truly out weigh the isolator.
Here's a video explaining the charger.
https://www.youtube.com/watch?v=0AGafmkFjN4&feature=youtube_gdata_player
dno67
The question is a little unclear to me, are you looking to add a duel battery system and then
add panels at random times while camping or put a panel on the roof or similar ?
If it were me, would be looking for an off the shelf duel battery kit, this way you'll get the cables already made up. Fit it up yourself, then fitting an Anderson plug somewhere (either the back of the car for power a CT or under the bonnet and then just plug your panels in. Another option would be then fitting something like the ctek dual 250s mentioned above close to the battery and removing the reg from the panel.
hiluxdriver
sorry for the PM Gav, your way too quick for me
I am limited to a smallish battery because of the location for the tray. I was told if I want to run a 60 ltr fridge a smallish battery wont last long before needing a recharge which is why I'm thinking solar for a boost. So yeh it would be at random times while camping a few days.
Something else I'm thinking of is getting a big mother flippin battery and putting it in a box in the car somewhere, but I'm not sure I want to do that.
03hilux
Why not run an AGM battery in the back? Then you're not limited so much.
dno67
Your probably best to work out how many Ah a day your fridge will use, this will also help with panel
selection.
I am using a Redarc BCDC1240 charger that will allow a connection from the car and solar as well as MPPT (Maximum Power Point Tracking).
The Redarc unit will sense when your car is running and only charge the auxiliary battery at that time.
You will need a change over relay to switch the unit into Solar mode but these schematics are all available on the Redarc web site and pretty easy to set up.
Hope this helps.
Jason
Gavo
Hey jase you put any more thought into which way you're going to go?
Sent from my GT-I9300T using Tapatalk 4
