bally
Banned
GQ patrol
Good Points
more torque then i can poke a stick at, strength, availability of parts
Bad Points
bashed the old rig up a fair bit over the last year so time to strip it down and clean it all up
What mods have you done?
gu diffs with 4.3 ratios and chinese air locker (work as good as arb/tjm at $1100 for two lockers and compressor delivered!!) 3" efs coils, 6" dobinsons shocks, slimline one off drop boxes with custom slders built into them to stop from being hung up when reversing, 10mm spacer in rear mushroom bush to stop from over compressing nushroom bushes and reducing flex and bush life (one of the best suspension upgrades, car drives like normal but flexes like it has superflex arms in it (which it did...) and doesnt destroy mushroom bushes so fast) hd 11mm+ rear lower arms, adjustable panhards, hd adj draglink and tierod.
td42 fully rebuilt, 12mm Diesel Central injector pump with high flowed ht18 (shit turbo, soon tobe td05 18g with 6cm rear) at 19psi. 3" straight through exhaust
tube winch bar, rock sliders and rear tube bar +1/4 chop, runva 11xp, lots of led's
What mods are on the list to do?
contemplating a style side extra cab chop and respray, need to strip it back down and replace all door internals and give it a good clean out.
Why did you buy this vehicle?
didnt want to break all the time soooooooo bought a NISSAN
How often do you go offroad?
most weekends either track making or leading groups/recoveries
What will your next vehicle be?
suzuki sierra
Good Points
Bad Points
suzuki sierra
