FABRICATION
(this is proving to be quite a long post, so buckle up)
The first thing I started working on was the mounting plates (or "Feet") that rest on the tub of the Jeep. I made these out of the largest piece of square hollow section I could find:
I won't bore you with the details, but these feet were incredibly annoying to make.
Basically it involved a bit of cutting with an angle grinder then lots of bending with leavers and clamps in the vice and a hell of a lot of bashing with a hammer:
The hole in the upper right is where the bolt that holds the hardtop goes through. The "window" in the bottom left is because the hardtop has a join in the back corners and a seam bulges out such that the plate wouldn't fit snugly unless I gouged out the window (sorry don't have a photo to explain).
I then lined the underside of the plate with vinyl to protect the Jeep:
This is the same vinyl they use in hospitals where the wall meets the floor to save the wall getting scuffed.
If you look closely you'll be able to see that I gouged out a channel in the vinyl to enable the plate to snug up closer to the tub.
Note: I have since replaced the vinyl with rubber.
And this is how it fits on the Jeep itself:
Again, if you look closely you can see the lip of the tub nestling into the channel I gouged out.
Next was to work on the frame of the rack itself.
The ProjectXXX rack (with the
excellent blog) was actually built using straight sections of pipe and welding in elbow joints. Originally I intended to do the same but ended up opting for tube and bends instead. My reason for originally considering "pipe and elbow" construction was mainly because I didn't have access to a tube bender, and I wasn't even sure all those bends were going to be possible with a bender anyhow. I did however have access to a good welder (boiler maker by trade) and he was willing to spend a few days swinging welding rods for me
I ended up however deciding against the "pipe and elbow" construction for a few reasons. One was the incredible amount of work it would require. If we were to opt for elbow joints all told there were 40 but joins that would need to be welded. Another concern was the weight. Using pipe I would be after 2" schedule 10 which had a wall thickness of 2.769mm, which has a weight of 4kg/m. It would be an option to drop to schedule 5 (with a 1.6mm wall thickness) but the welding would be a lot more difficult, so I ended up deciding to opt for bending instead. After a bit of searching and a few phone calls I landed on
BDL Holdings who have a "Mandrel" bender and were happy to sell me 2" tube at $10/m and bend it for $10 per bend. I was set!
After pulling apart the model I concluded there were 8 lengths of steel I would need to have made:
In total I would require 22.6m of tube consisting of 24 bends.
The bender BDL have is capable of bending 2.25" tube in a radius of either 87mm or 110mm. So I modified the design to employ 87mm and 110mm bends and sent off the plans for the first piece of steel.
I wanted to get just one piece first to make sure I had the dimensions rite, so I ordered the "Rear Hoop" first:
Here is a copy of the actual diagram I gave them:
Note: I ended up lowering the rack 50mm and this image is what I should have ordered. The actual diagram I sent can be found here.
And sure enough, a while later it was ready to collect:
It was really exciting to actually have the first piece of the rack proper in my hand
There is a bit of "green" on the ends of that first piece, but after lobbing them off it fit perfect so I ordered the "Front Hoop" and "Ladder Rungs":
This gave me enough to build the first free standing section:
The "Hoops" where easy enough to trim to fit. Then came the scalloping of the ladder rungs.
They weren't that hard, just annoying.
Basically it just involves a lot of this:
I did manage to find a cute little program called "
Tube Miter".
It's a simple little program that creates templates for you to print out and follow when scalloping tube:
Anyway, when all was said and done I had 12 nicely scalloped lengths of steel ready for assembly:
Next was to break out a welder...
After a lot of toing and froing it became apparent that things were going to take too long with my original boiler maker mate so I reached out to the forum community for help, and I must say I was most impressed with the response!!! Nightscale, an experienced welder, offered his expertise and another member generously offered me use of a 150amp MIG welder
First thing we did was to suspend the "Rear Hoop" from a pulley mounted to the roof of the garage. I then backed the Jeep up to where the hoop was suspended and we tack welded the hoop to the mounting plates (feet) that were bolted on the car. We then did the same with the "Front Hoop" and tacked the "Ladder Rungs" in. Once it was all tacked together we removed the rack from the car and welded the joins properly:
Nightscale working his magic.
Once all was done we did indeed have the first free standing section and it looks pretty much exactly as expected from the rendering:
Flushed with the success of this first section I thought I'd try my hand at swinging the welding gun myself
I decided to cut a couple of links from a chain and weld some lugs onto the rack so I could raise and lower the rack with the pulley:
It works fairly well.
I can now hook a chain onto the lugs then raise the rack up to the ceiling with the pulley:
However, as can be seen in the "ground level" photo of the rack on the back of the car above, the rack looks to ride a little higher than expected and kind of looks a little odd. The gap between the roof and the rack is between 75mm and 80mm (which I thought would be a good amount of clearance) but when on the car it appears to be too high:
Another issue was that the gap between the lower and middle ladder rungs is larger than the gap between the middle and upper rungs:
Most people wouldn't notice but it annoyed the heck out of me!
And the ladders of the rack kind of protrude out the side of the car more than is necisary (particularly at the bottom):
All this led me to decide to remove 50mm from each of the 4 vertical sections that connect the top of the rack to the mounting points (which I refer to as 'legs').
To accomplish this I decided that rather than simply removing 50mm cylinders of tube from the 'legs' I would remove "chevrons" instead. This I thought would not only make the join stronger but would also make the join itself less noticeable in the finished product.
So I set about drawing up a template:
And cut it out:
Using the template I then marked each of the 4 legs:
And cut them:
As you can see I also 'staggered' the cut so as to try and obscure the joins in the final product:
When putting the 'legs' back together I decided I would make internal 'gussets' to give the ends something to weld to. I made the 'internal gussets' out of the same tube I used to construct the rest of the rack:
I slit these down the side and removed a strip of material to enable them to contract and fit inside the other tube:
Then hammered them into the 'legs':
As you can see this makes quite a good looking join:
And here is the rack 50mm lower that it was before:
While removing these sections from the 'legs' does indeed lower the rack by the desired amount it also brings the 'feet' closer together:
This meant the feet had to be cut off, the ends of the tube trimmed a little then the feet welded back on.
The next part to work on was the lower 'S-Bends':
These required tube to be bent with the larger 110mm radius:
Now the whole purpose of the 'S-bend' is to enable the rear wheels of the buggy to straddle the front part of the rack. After a few measurements the width of the rack, from outside face to outside face proved to be 1330mm, and the distance between the rear wheels of the buggy (from inside face to inside face) proved to be 1265mm. This means both sides of the rack will need to come in 32.5mm in order to accommodate the buggy.
After a bit of scratching on the pavement with a stone (and not to mention scratching of my own head) I managed to calculate that the tube needed to be cut at the arcsine of (110 - 32.5)/110, or 44.8 degrees:
As an aside, at this point I would like to thank Mr Forsyth (my year nine geometry teacher) and acknowledge (begrudgingly) that yes indeed trigonometry is useful in the real world and that it does indeed show up in the most unlikely of places
Anyway, with the drop saw set to approximately 44.8 degrees:
I was ready to start cutting:
After joining the two ends of the 'S-bend' and a quick check for fit:
It was time to fetch another piece of tube for the front cross member:
So I headed back down to
BDL Holdings again and strapped another piece of tube to my noble steed:
And brought it back home to put on the rack
Then things slowed down for a bit...
First there was this:
Which was followed by this:
And eventually resulted in this:
But eventually, when I had a good friend over from Finland and I once again found myself between jobs, with a new set of wheels under her, the roof rack finally started to progress again.
We started working on the project in earnest and things were looking good again, but then we hit a problem...
You see, this was a primary design constraint of the original design:
350mm between the roof of the Jeep and the top of the garage entrance.
But with the new car (which has a 2.5" lift and 33" tyres) the picture looks more like this:
This roof rack was designed with very tight constraints and 250mm clearance was just not going to go, so I had to improvise a little redesign.
As a start I decided to make the entire lower level one height and leave the "basket" for a later time and have been toying with ideas on how to make a 'detachable' basket. Unfortunately opting for a detachable basket means that I have had to for go the double front side arms and just have single side arms:
This was a real shame as I very much liked the look of the double fronts and had spent a significant amount of time perfecting there look. But dems are the constraints
This is what the lower section should look like now:
Then came the next hurdle...
I had always intended to weld up the rack as one complete unit (much like the ProjextXXX guys did) and lift it on and off with the pulley, but I then realised there is no way my garage roof would be high enough to lift the whole rack atop the car. Previously to get the back section on and off the car I would hoist the rack up a little higher than the back of the car then back the car in underneath it. With the front arms on it wouldn't be possible to back the car in any more, so I had to come up with a design to allow the front arms to be removed.
In the end I decided to have the front sections as "hockey stick" shaped pieces and bolt them to the main rack using internal plates.
The way the joins would work is to cut a short section of tube and slit it in half lengthwise. I would then compressed the halves in a vice so as to bend them such that they were able to fit inside the original tube, then drill holes in the tube of the rack as well as these internal plates such that they could be bolted in place.
Here's a prototype I made while thinking things over:
In this photo the connecting plate is on the outside of the tube but in the final design it was on the inside.
And here is what it looks like with the bolts attached:
Here's a photo of the inside of the tube:
Note that the bolts do not quite reach to the centre of the tube which means you can have bolts in both sides with out fear that they will hit in the middle.
After being satisfied it would work I started making the real ones:
And welded the nuts to the inside:
Then drilled holes in the main frame for the bolts to go through:
Next it was time to make the front legs (or 'hockey sticks' as we call them)...
Amongst there various utilitarian abilities Wranglers somewhat bizarrely have the ability to fold there windscreens down
I can only assume this is a throw back to their military origins where the occupants of a Jeep may have wanted to be able to shoot with out getting out but these days it just seems a curious and bizarre relic.
In any event Wranglers all have removable Y-shaped pieces in there corners to enable the windscreen to fold:
My plan was to simply buy replacement brackets and weld the hockey sticks to these pieces:
Once these 'hockey sticks' and joiners where made all that was needed was a quick coat of paint and she was ready to go on the Jeep:
And here it is as she now stands:
