Coleman Hot Water On Demand Review
Ive had this unit for about 4 years now.I bought it from Rays on a Special with the Bag etc etc.Pricing is all over the place on the net..Caravan and Camping Shows generally produce value for money with bundling gear with it...
This unit has been brilliant for showers while away and also for hot-water for doing the dishes ..I found the the hose they use is terrible and hard.I went to a boating joint and replaced it with a more flexible hose,remember if you do this and its too flexible when it gets hot it could crimp the hose cutting off the water supply.Also the shower rose is also terrible and i replaced it with a shower rose from Bunnings..Its all great now..
I find this unit is not hot enough for a cuppa coffee or tea..If you dont have milk it maybe ok.It also has a 12volt battery that is removable should it need replacing,mine still holds its charge very well..Its for the ignition to light the gas burners to heat the water..Water pressure is good enough to get the job done.It also has a safety spring so that if you want the water hotter you have to personally stand there holding the knob around until you've got enough hotter water..
It comes with 12/240 volt power adapters.
I also find the 20litre Collapsible water containers are great,i hav x2.There flexible although full of water so i take them even if i leave the shower at home which isn't often.I like to shower every-night after a days worth of 4wdriving... If the rivers to cold a hot shower is fantastic and refreshing...
It takes the Coleman Propane Canisters which i notice have doubled in price over 4 years from 5 bucks to 10 bucks,there generally a throwaway canister..
It has been a fantastic addition to my camping gear...
OK Ive noticed there is a new Aqua Cube that's taking on the Coleman,with digital display etc etc..I am trying to get hold of one for a few months to try it out and then return it for a review,cannot promise anything but will try...
Coleman Hot-Water Specs:
Hot water dispenses from the faucet in less than five seconds, adjustable up to 160° F (71.11° C)
Full size faucet fold into handle
Heat up to 40 gallons of water with one compact Coleman® 16.4 oz. (465 g) propane cylinder (Propane sold separately)
Water flow is 1 gallon per minute on the warm and cool settings. It is about 1/2 gallon per minute on the hot setting
For even more hot water, adapt to a bulk propane tank (adapters and tank sold separately)
Rechargeable 6 volt battery pumps the water
Battery can be recharged in the car or off of a household outlet
Recharge cords store inside the heater
Simple to maintain: clean the heater with a simple household solution
Portable, propane hot water system for outdoor use only
Great for emergency preparedness
3 year warranty ...... (Now 1 Year)
Dimensions: 17 in. x 9.6 in. x 16.1 in. (43.18 cm x 24.38 cm x 40.89 cm)
Made in China
The unit hooks up to these Coleman Collasable 20l Containers, usually about 10 bucks in the U.S but because we live in Australia We have to pay 3 times more, Google Apples response to why there song pricing is about 50% more in Australia and, basically it's because we pay it.
So the pump end screws onto this container once full of water, 20 litres will give you about 10 minutes showering .
Also if you have mains water you can buy an after so it runs off your hose for about 60 odd bucks.
If your very careful you can use the units pump down by the river to fill the containers back up, but do at your own risk because if the pump fowls up with mud, leaves etc it may be the end of it, I've been doing this for years in Prestine water tho and never let the pump hit the bottom and had no issues.
Update
Ok if you find the water pump or ignitor will not work its likely to be the internal fuse. PLEASE be aware opening your unit will void your Warranty, I suggest you only try this if it's run out. I found this on another forum. So what causes this fuse to blow, well reading another site its likely to be the pump at the end of the hose.
Replacing internal fuse on the Coleman On Demand Hot Water Unit
Also from another site is the Coleman rep who apparently is the guru on these units :
Coleman rep for hot water service..
*Max on 0418 849 693.*
Independent Reviews at the Coleman Site Here:Coleman - Outdoor Gear for Camping, Hiking and Tailgating / US
Note:
These Reviews i write are from my own Camping Gear that i have bought over the years that i have used and paid in full...Ive decided to write these reports so my fellow 4x4Earthers can make a valid choice on what gear to buy whether it be of high grade quality or poor quality.
Made in China
Update
Note:
