4x4 Equip Combo Shovel & Bag Review
Combo & Compact Shovel Bag Review
OK thought I'd review this shovel set i bought after looking on the net a few years back,Ive used it around the backyard and also sandy soils here and there near rivers as some areas get washed away and you need to move/fill in areas,Ive used the rake many times before putting down my Swag,raking away sticks.leaves and small rocks,its very strong..Now i wasn't going to put the Rake up as i bought it a few years back when picking up the shovel combo set and i only saw it out of the corner of my eye,I asked him about it because there was two left in a corner.He said one was his because he had sold a few and hadn't kept one myself lol.. So you can have the other one for about $25 bucks from memory and I'm glad i grabbed it..
The story goes he had lost the manufacturer for the rake and was in the process of getting another as the demand for the rakes was huge and i fully understand why.There not on his site yet so i dont know what the story is...This guy actually makes the shovels himself with many other top notch products on his Website..He usually goes to the Caravan Camping Shows around the Country...Well Ive seen him at Caulfield Caravan Show so i gather he goes to others.
Its meant to say Keeps the tips of the Rake safe...lol..I will fix.
Specs for set below:
Combo Shovel
The unique 4x4 Equip has proven it’s self over several
years now. This improved design now makes the even
better. The takes away the hassle of trying to carry a
long handled shovel inside or outside your 4WD. Simply un-screw the
long handle at the threaded joint and store it conveniently away.
By attaching the supplied 'D' handle it now becomes a useful
spade. The high quality is built strong for hard work
and consists of a heat treated steel blade, multi-core, steel reinforced
fibreglass handle, cushioned "D" handle and steel joining sleeves.
Technical Specifications:
Steel Reinforced Fibreglass & PVC Handle, Zinc Plated Steel Threaded Joining Sleeves
Long Handle Shovel Length 1430mm, D Handle Shovel Length 970mm,
Minimum "break down" Length 770mm, Blade Width 193mm
Ok the pink flagging you see on the Rake is for visual purpose only,I put it on everything that can be lost in the grass...Even around my Coleman Northstar Bag which is Green and blends in quite easily in the grass...So theres another tip,i haven't lost anything yet...lol
You can also buy a Axe and Shovel Holder that goes on your spare wheel if you have one one on the rear..He also does shovel holders for Roof-racks...
The products can be found here: 4wd Recovery Gear | 4wd Accessories | 4wd Equipment and Camping Gear Australia | Axe and Shovel Holder | Combo Shovel | Synthetic Winch Rope | Camping Lights| Autofridge Eutectic Refrigerators|Pillowtrack|Tyre Deflators|Versa-Lite|LED Strip Lights|Fr
From 4x4Equip: Don't be fooled by poor quality imports. These copies may have no internal steel reinforcing. They may even feature a washer between the two joining sleeves which drastically reduces the strength of the shovel and places undue stress on the thread.
Note:
These Reviews i write are from my own Camping Gear that i have bought over the years that i have used and paid in full...Ive decided to write these reports so my fellow 4x4Earthers can make a valid choice on what gear to buy whether it be of high grade quality or poor quality.
Combo Shovel
Note:
