Commercial awning problem
Les PK Ranger
Just a heads up.
If you have an Ironman or other such awning (I think they are all made / fitted up the same), then it might pay to put in some extra rivets !
On the way home today and the misses says you'd better take a look at the awning when we stop, its loose.
Sure enough, home a few minutes later and the back 3 rivets holding the thing together have come away, the back one gone and the next 2 still with the slug in the back.
This is where the 2 ali flats pop rivet together with the awning, awning cover, and the 3 straps in between.
Lined the cover and straps up again, drilled the holes out, and pop riveted new heavy stainless ones back in there.
Also put in some new ones along the top, still in the enclosed back section, maybe 1/4" or so above the ali flange where the poles are placed.
Offset top rivets an inch or so.
See pics.
The way the existing rivets are located below the centre line of the whole thing causes it to pivot away easily and it will likely fail eventually.
They should really have the top row of rivets in there standard.
I have given it a few trips that tested such a fitting, with lots of sand hills etc.
Les PK Ranger
No worries, yes an easy fix and well worth half a dozen rivets.
I used longer rivets to get good bunching behind, as I did the fist nip up, keep the rivet gun held in well and it pulls up nicely.
A lot less downward twisting on the whole thing now.
Cheers,
Les
hornsbymaso
Size of rivets
Just a heads up.
See pics.
Have just purchased awning and it came no instructions on how to fit to roof racks.
Came across your post re bracket fixing and strengthing.
Are your racks Rhino? look very similar to my Rhino racks.
Also did you reduce the width of your brackets to fit into racks?
The size of the rivets that you used? (dia. & length)
Have some SS rivets but they are a bugger to use, so hard to snap the stems.
I am only a newbie to this page and what you have shown in your post has been very helpful.
Regards
Maso
Yeah good stuff Les, will have to check my one out..Although i take rivets away and a pop riveter i just thought there's no drill in my kit :eek::eek:..
A Pop riveter's know good if you havnt a hole..:eek:
Les PK Ranger
Regards
Maso
Sorry Maso, missed your post, and didn't seem to get an email message re thread update.
Anyway, my racks (2) on the canopy are the ARB ones, same look profile as the one over the cab, which is Thule.
The slot in the racks are the same, 20mm x 3mm.
Mate, I used 1mm cut off wheel to get most of the excess bracket sides off, then a grinding wheel to finish . . . from about 23mm wide down to 19mm.
Grinding 3mm stainless bracket is freaking hard work !
Doing the 3 brackets might have taken me a couple of hours.
I doubt I could get them out easily either :/
I can't recall rivet size used, they were good dia, probably 5mm or so, but lengthwise only had to go through the 2 ali extrusion thicknesses with the cover material between them, so probably 10 or 12mm or so would be ok (best measure your extrusion walls and go from there).
Yes, the stainless steel rivet stems were very bloody hard to snap !
Yeah mate, lucky mine came adrift on the way home from the local shops, was litlerally a few minutes from home and tools.
There are small cordless drills out there, how good they are is another thing.
Suppose they'd be good for use with screwdriver bits too, so might be good to have one in a group somewhere on big trips.
Alien d2
Thanks for the tips Les, it looks fairly simple to do at home.
While I have mentioned this thread to others I didn't think I'd need to revisit it myself.
Having just got back from a trip to the southern flinders/danggali/murray-sunset I now have a rivet missing and 3 loose.
My Ironman unit has a slot for each side rail/pole so it will will easily take the extra rivets .
Les PK Ranger
Cheers cloughcarb, bloody good point mate . . . I didn't even consider electrolysis in that . . .
Found an interesting site, and indeed there can be problems with SS and Ali together, read thread Is Stainless Steel Corrosive to Aluminum? - Airstream Forums
Even though an electrolyte such as water / moisture needs to be present, this is possible even though inside the awning bag.
I did seam seal my awning bag joins, sewing stitches etc fairly early on to try and keep moisture out of there, but still it could get in as moisture can (wet awning rolled up would be one sure way).
Just realised too that the backs of the rivets go into a channel, which could be exposed to water / rain ingress.
I'm going to keep an eye on mine and drill them out if I see anything going on there with corrosion.
Either prime / seal and use SS again, or I'm sure heavy duty Ali rivets would be ok to use there as well.
dimeglio
Just a heads up.
See pics.
Hey did u have to take the black piece off the roof rack to install the awning?
Les PK Ranger
Yep, removed plastic ends, knocked in ground to size brackets, had to trim the rubber in the slot to suit, put some small tank bolts through the brackets and bar.
Used locktite and spring / flat washers.
Les PK Ranger
I don't reckon these black end caps are designed to keep water out, even the rubber infills won't do that.
Water ruin the roof rack ?
Not sure how it can do that, they're in water whenever it rains. :)
On mine you could open the little bits at the end and slot in the brackets, leaving the flap of plastic hinged down, but this would have looked worse, and the plastic would have flapped about in the wind etc.
cokeaddict
Just a heads up.
See pics.
Hey Swaggie,
Hope your well mate.
Read your review on awnings a few times before deciding to bite the bullet and get one.
Got the kings 2.5 X 2.5 unit and finally set it up this week. Changed a few things like brackets and bolts to suit my needs. Also made it so i can use single roof racks (as in the pics) Or slip it into my alloy roof rack for longer trips away. One thing I noticed from your review mate is that they now use more rivets. I counted 10 in mine. I will take your advice later and add maybe another 5 or so more to the top row. I am glad I got the 2.5 as i can see where that extra bit will work for those wet days.
Thanks again for the reviews mate.
Blue_haired_man
Just a heads up.
See pics.
Thanks for the heads up les, it looks very similar to my awning.
Les PK Ranger
No probs Leo, good to see people are still seeing this thread to get an early fix to prevent problems on the tracks.
