Conflicting service intervals
SIX36
So i have been given conflicting service intervals on my 2010 Diesel Colorado, after first service was told and written quoted 15k km and a 7.5k km oil change...
Call up to get a oil filter and am told no oil change till 10k km service which is the next major service...
Rule of thumb same as my bikes is change oil more often that service manual...
So what's true?
BUSHNUT
15,000 SOUNDS A BIT OF A STRETCH ! I am doing my D MAX every 10,000 and I am using synthetic . The recommended duration is 10,000 with Isuzu , it is the same motor in the diesels at the moment .
Mammi motors in Somerville who service my truck run 2 D Maxs and have tested the oils of there own and concur that Isuzu is correct especially with the synthetic .
My prevoius truck , GU ute was serviced every 5,000 , oil , filters the lot .
monk2
my missis drives a korando which has 2.9 intercooled TDI and I service it every 5000klm cheap insurance, new oil and filter are the cheapest things to do to maintain the engine it might be one of these new diesel motors with all of the electronics turbo merc engine but they still turn the oil black as the ace of spades, change oil and oil filter every 5000klm
SIX36
Cool, will stick with the 10k and oil every 5k...
Servincing her is all good just didn't want to be giving the stealership more $ than needed...
My bike is serviced every 10hrs and 800km for transmission oil...lol
Joe
Holden recommend 15,000km intervals for the Commodore, but I prefere every 10,000, and with the ute, I'll be geting that done every 5,000km.
Yeah i do the same with mine,Fuel filter is done every 10k
NIAL8R
HiLux 2.8TD every 5k inc diesel filter, think the book says 10k if only been used on the black top.
VY SS every 20k unless it been on a few big runs then i knock 10k off
ZX9R road bike every 10k unless it been on a few big runs then knock 5k off
dirt squirters get done after every weekend rides, between 10 & 16hrs
ISUZUDMAX
Service Colorado
The service intervals for a Colorado should be the same as for Dmax. 10,000km is ok for engine oil, the dmax has a large filter and with good, yes good oil, in normal use it will protect well. If the oil condition deteriorates you can always change it if it appears to be getting dirty.
The oils in other sections must be changed regularly and a Colorado requirements shouldn't be compared with that of a Commodore.
Some dealership serviced vehicles haven't had proper changes, this is unfortunate.
The owner must take charge and make sure their services are completed correctly by whoever performs the service.
It is probably a bit academic to discuss if the service should be done at 7,5k or 10k if the service agent doesn't so it properly whatever the km.
Just make sure it is done and the best of lubricants are used. This is the best insurance of all.
isuzudmax
10 or 15k, it don't matter really, there us bugger alll to do, stuff all gets done on new vehicles, a service is a checkover, no such thing as major service anymore!
If you really want to look after it, oil every 5000klms, oil & filter every 10k.
sandgroper2
Synthetic oil
You really should be getting more than 10,000km on a good synthetic oil. You might want to get some oil analysis done at around 10,000 to determine the soot content and any other contaminants building up. You might be quite surprised how well it is performing.
Rigseismic67
Colorado servicing costs for 2009 TD 4JJ1
I have a Colorado diesel 2009
Just been down to my dealer- Commonwealth Motors in Phillip ACT.
They quote the filters as Oil $60- fuel $90 and air $110!
That adds up to $260 for 3 filters
On line genuine Isuzu parts from Baulchs are only $139 total including the postage, how can GMH mark up these prices by more than 100%?
My car is still under warranty (just) and it needs its 40k service, its going to be painful.....any recommendations in Canberra area????
redandy3575
I'll back that. A top quality synthetic oil is said to last up to 20,000km
Also, it is not a bad thing when oil goes black. It means that the detergent properties are doing their job in trapping the soot and contaminents.
It's all based on where you drive and the conditions.
ISUZUDMAX
G'day Rigseismic67
I priced filters for a Dmax and also at the Oldhen dealer the same day. The Oldhen wants abour $95 more for the same filters.
You can buy the 3 filters in a set from Donaldson Filters and the 3 of them costa about $75 all up.
I can't help with who can service for you, but advise the marking of many items, filler plugs, old filter, cam cover bolts, because they are supposed to do the valves at 40,000km.
Do not be surprised if you pay for the service and much of it isn't done.
If nearly at the end of warranty period I would get a reputable 4wd place to service it with Donaldson filters and good oil in the transmission and drive line and also good oil in the engine. Most dealers don't use good oil.
Use Delvac MX ESP in engine.
