03hilux
Hi, I didnt think to take photos while i was building a drawer for my Hilux until i had installed it.
The outer box is made from 15mm CD ply, and the drawer has a 15mm base, and 13 mm sides. The ply cost me $85 from Mr Plyandwood.
Carpet, glue, stainless screws and cup washers,Black spray paint, and fibre glass resin, and 20mm alu. angle cost $ 80 from Bunnings. For the drawer slides, i bought 2 lengths of boat skids from Bias boating for $12 each.
All up, it has cost me $190 to build.
I had the resin tinted black and used it to seal the drawer and the cabinet base. I glued the carpet to the cabinet sides and top. What wasnt carpeted was painted black.
The handle is a piece of off cut from the 20mm angle.
On the top i cut out a hatch for the 2nd battery, as i made the draw short, purposly to house the battery behind it, and i cut out a hatch over the wheelarch so u can hide my jack and towbar fitting. The drawer is L shaped to maximise space around the arch. The cabinet sits 25mm off the rear bulkhead so it allows the battery to breathe, and stiil allow access to tie down points.
Including an hour shopping for the parts, the drawer only took 5 hours to build, carpet and install.
