1 red gu
Ok here is my DIY rear bar finally finished
It has only taken me since xmas (small work in progress
) but here it is
I started off with my brother’s wrangler rear bar and cut it in half. Then made up a step in the middle to lengthen it to suit the GU. I then added two stub axels for some swingers then grafted on the sides and bent up some flat around the back lights for that factory look. I have also cut two slots for the LED tail lights in the bar.
It stayed like this for a while till I got the urge to get stuck in to the swingers. Started by getting on the lath and turning up the housings for the bearings to sit in. Then set out on the bench what I wanted and cut all the steel up. One to hold a 33” Tyre and shovel holder with a reverse spot light and extra CB aerial. and the other to hold two jerry cans or a jerry and my chain saw.
The locks I used on the swingers were just like gate locks with the lift up pins, I thought this would do for now, but on the first trip with it the locks snapped with in the first hour off road.
So it was back to the drawing board. After looking around I called up millweld and had them send up two of the locks they use on their bars. I than had to makeup mounts for them on the swingers and get them installed.
It has turned out great and the new locks are very strong here is some pics of the epic build
