Re-Installing Warn 9.5XP Winch
surfer
Well on the weekend my motor chucked a hissy fit and decided not to work anymore.
To cut a long story short the person who installed the winch did not remove the drainage plug and water go into the motor and rusted it out.
In the end the motor was replaced with a new 6hp motor direct from warn.
I have taken images of the re-installation and thought i would share it.
This first image is the start, a bar with no winch!
The control box was installed previously to the motor chucking a hissy fit!
But if you have your control box off it is 3 wires to the motor and and 2 x earth wires, pos and Neg to the starter battery! that's it.
Don't forget to remove the pos and neg from the battery!
I took a picture of the new motor, taking note the sealent where the motor joins to the winch!
Next is lowering the winch in place and aligning the holes!
All tight and cable attached to the drum! Cables attached to the motor, making sure all the connections are covered to prevent short circuit.
Don't forget to reconnect the pos and neg to the battery.
Cable spooled on under load!
Finished Project! - The spot light had to come off to make getting access to the winch!
NIAL8R
good on ya Scott, this little right up should help those that might get stuck someday :D
How many meters ya got on ya spool ??
Alien d2
So was the drain hole at the top on the old set up?
Good thing winchs don't BEEEEEEP when their full of muddy water and faulty, unlike an alternator:p
surfer
Lol, No as Warn is made in America they bolt there winches down, and that means the drain hole is down, I have mount my winch Forward which ment that the drain hole was facing half way, I did not get any images of the old motor, :mad: But it was rusted out half way, two of the four magnets were completly covered in rust.
No mud present at all......
Now the funny thing is that Stewart from Induro Offroad has mounted his winch exactly the same, (Yes he has the exact same winch installed for over two years) and he has not had this problem. My went in two months......... :eek:
The repair turn around was fast as I drive from:
Roxburgh Park to Lilydale - Patrol Apart to pick up the winch
Lilydale to Notting Hill - To pick up the new motor
Notting Hill to Blackburn - to have the motor installed bu Induro Offroad
Blackburn to Roxburgh Park - Got to get home to make dinner!!!
I left home at 11:30am and arrived back at 5:30pm.
I will say if you are not sure about installing a winch get it done professionaly as the responsibility was theirs for the motor going.
If I installed the winch then I would be forking money out of my pocket to buy the new motor!
Regards Scott
deepop
Well done Scott - that was quick!
At least I can't be blamed for destroying that bit of machinery - and the one I did use (chainsaw) is still working I presume?
surfer
There's no problem with the chainsaw, it's a stihl.
It just needs a good service........
The water in the trees I was cutting pritty much saw the sharpness go in the chain.
But it did keep cutting or should I say Ripping through the wood!
I thank you for all the work you put in cutting and the day it did turn out to be a great day except for the trees. Hey thats 4wding.
Hope to see you again out on the tracks soon!
Regards
Scott
Hiya Mate
I hate to crash ya party but it will seize again after some serious river crossings where the winch gets a soaking..I pulled my motor apart after the brushes seized (and i do believe people hav been ripped with a new motor instead of cleaning it up) cleaned them all up and the armature and sprayed lanolin all over the electrics and sealed my motor end from water entering it period.To allow water over electrics is just braindead..
In the past My 9.5XP has let me down at the worst of times.Since fixing the issue its been ok so far....
Oh go to a park or somewhere where u hav space,unwind and wind say every 6 weeks under load to keep it happy...And how in the hell did ya wind it back on so neat ?????....lol
surfer
Hiya Mate
I forgot to take images of the old motor, you would have seen rust eating away inside!
Normally the comutator slides out easily, this had to be forced and in the end I still couldnt get it out.
The motor is completly sealed both drainage holes have been sealed.:D
All the way around where the motor attaches to the winch body.
Can water get in anywhere else?:confused:
I just connected the hook to the shackle and tree protector and started to wind it in slowely.
Took me 30min....... :eek:
Looks awsome wound on so neet! :D
