Mn glx-r factory diff lock problem
Discussion in 'Triton' started by Sledge83, Mar 4, 2017.
  1. Sledge83
    Sledge83 New Member
    2012 glx-r
    So when I select 4LLC it goes into low range and centre look engages
    But the rear diff lock is not lighting up at all on the dash
    What could be the problem and where to look?
    Thanks
  2. phs
    phs Well-Known Member
    Look behind the switch and make sure it's plugged in, seen it happen on a challenger
    Spooner likes this.
  3. Spooner
    Spooner Well-Known Member
    Is it a manual or auto ?
    Also main point I can think of is are you stopped when selecting ? . A couple of my friends have them and stop in neutral 1st . Then select and put into gear and away you go.
  4. Sledge83
    Sledge83 New Member
    Manual tried stop in neutral and first no joy
  5. Spooner
    Thats no good mate , all I can suggest is what @phs said , check the switch plug .
  6. Sledge83
    Sledge83 New Member
    Switch is all good
    Dam I was hoping something simple
  7. Spooner
    It probably is mate , contact a Mitzi mechanic and ask the question , it could be a blown light thingy. Have you check if diff lock is working or not ?
    Shouldn't be too hard to find out.
  8. Sledge83
    Sledge83 New Member
    Thanks for the input
    Will be having a play with it tonight fingers crossed it's something simple that I just haven't thought of
    Spooner likes this.
  9. Spooner
    9 out of 10 times it is , so don't sweat too much :)
  10. Toddyh
    Toddyh Well-Known Member
    Try actually moving slowly. These lockers will engage at slow speed.
    Otherwise start checking fuses and the air line. The air pump is located above the rear axle on the passenger side.
    Spooner and underdog like this.
  11. callmejoe
    callmejoe Active Member
    My diff lock wont engage or disengage unless I'm very slow moving. Takes about 5 to 10 m depending on the terrian.
    It's a Nissan y62 but still electronic engagement so they could be of similar set up..
    Spooner likes this.
  12. Sledge83
    Sledge83 New Member
    All fixed it was the airline
    Thanks to all for the info
    Appreciate it
    tankbloke likes this.
  13. ron Jones
    ron Jones New Member
    With little faith in factory stuff I went for the MQ GLX auto and fitted an eaton rear diff locker winch and bar. Cheaper and better I think.
