1HZ Fuel Pump Filter
Discussion in 'Fuel System' started by brett46, Sep 22, 2010.
  1. brett46
    brett46 New Member
    Does the 1HZ fuel injector pump have it's own internal filter? I have a 95 L/C 80 series non turbo. If so does it need a special tool to remove? Cheers Brett
  2. Joe
    Joe Active Member
    G'day Brett. We have a '92 80 series with the same engine and as far as we know there is not a filter inside the injector pump.
  3. Jarh73
    Jarh73 New Member
    Some injection pumps have a porous bronze filter.
    Justin
  4. brett46
    brett46 New Member
    So does that mean my model has one? Was thinking of removing the the main feed line to check...... but would like to know for sure if theres one in there.. Brett
  5. Jarh73
    Jarh73 New Member
    To be honest I'm not 100% sure about your injection pump but it's quite common to find the bronze filter where the fuel goes into the injection pump. It's often removed on higher performance turbo engines to improve fuel flow.
    Justin
